warning sound.....
Old Mar 9, 2002 | 02:21 AM
DC350's Avatar
Rotor Head
warning sound.....
Hey everyone, when i drive my car for a bit...a beep beep beep beep, comes on like for a while, then goes away. My idiot lights dont work to well, i am getting another cluster soon...but does anyone know? all the gauges work okay...the temp is in the normal zone, the coolant seems full, (hasn't been changed in a while) the beepin goes away after, i have plenty of oil, i just did an oil change....bad ground? or what....PLEASE shed some light! Thanks!!
Evan
Old Mar 9, 2002 | 08:30 AM
RETed's Avatar
Power steering is beeping at you...
ARCHIVE THIS!
__________________________________________________ _______
I had a similar problem with a recently purchased '86. I would be driving
along when a beeping would emit from inside the dash. Soon after, my power
steering would feel more like manual. I checked my factory service manual
and discovered that the Speed Sensing Power Steering control unit, located
under the dash below the instrument panel, emits beep codes to indicate a
problem. There are six different conditions/codes:
1) 2-beeps, pause, repeat. In case abnormality occurs to the engine speed
signal. The buzzer sounds when the vehicle speed signal is input and no
engine speed signal is input (short circuit, broken wire, etc.)
2) 3-beeps, pause, repeat. In case abnormality occurs to the stepping motor
signal. The buzzer sounds when there are broken wires or short circuits
in coils or harnesses.
3) 5-beeps, pause, repeat. In case abnormality occurs to steering sensor
signal. The buzzer sounds 60-seconds after broken wire or short circuit occurs
to sensors or harnesses when the vehicle speed is above 40Km/h (25 mph.)
4) 1-beep, pause, repeat. In case abnormality occurs to speed sensor signal.
In case broken wires or short circuits occur to sensors or harnesses, the
buzzer sounds 60-seconds after the engine speed signal of 2200 rpm continues
for 18-seconds.
5) Continuous beep. In case abnormality occurs to the power steering
microcomputer. The buzzer sounds if the microcomputer becomes abnormal and
cannot control the system.
6) 4-beeps, pause, repeat. Also in case an abnormality occurs to the power
steering microcomputer. The buzzer sounds when there are circuit troubles
other than with the micro computer.
My beep code was #4 from above. I removed the control unit from my car,
opened the metal box it was in, removed the circuit board and resoldered it.
Upon re-installing, everything was fine. You might also want to first just
try removing the connector to the control unit, cleaning it, and then re-
connecting. I'm wondering if this could have fixed mine.
-Ted
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
86glxNA
Sep 15, 2015 04:20 PM
