84 13b into 85?
Old Mar 8, 2002 | 02:22 PM
84 13b into 85?
Will a 1984 13b bolt into an 85 GSL-SE as an 85 13b would?
Old Mar 8, 2002 | 02:26 PM
treceb's Avatar
yes. If Im not mistaken any engine between 84 to 91, be it 13B or 12A, are interchangeable.
Old Mar 8, 2002 | 02:56 PM
Directfreak's Avatar
I am a Jeeper Now.
Yes, If you use the front cover, oil pan, and Mounting bracket of the GSL-SE.
You could even use 3rd Gen motors if you swap those parts out.
Old Mar 8, 2002 | 05:41 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Well sort of theres a few other things to tend to But anything will fit anywhere... It just happens a 13b swap is an easier than 'anything'
Old Mar 8, 2002 | 07:06 PM
Max7's Avatar
Admitted Sevenaholic
Re: 84 13b into 85?
They will swap with zero problems
both 84 and 85 GSL-SE 13B's were identical cept for a few small things, of which none will cause any real problems in the swap
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
