Quick Porting Question
Old Nov 29, 2006 | 06:02 AM
B6T's Avatar
B6T
ERTW
My 13B produced 110psi in the front and rear rotors with a cold engine and doesn't smoke or burn excessive oil (never had to top it up this summer actually), so it seems like its in great condition. If I wanted to port the engine, what parts do I have to replace? Obviously gaskets need to be changed, but can I use the existing seals?
I'm not poor, I just don't want to spend money when it isn't necessary.
Thanks!
Old Nov 29, 2006 | 08:51 AM
Aaron Cake's Avatar
Engine, Not Motor
Unless the engine has really low mileage, you'll be doing a complete rebuild. So that means all seals generally. Often the side seals and hard oil rings are reused if within spec (wear is negligible on these items).
Old Nov 29, 2006 | 08:53 AM
Whizbang's Avatar
Respecognize!
if the motor is in that good of condition you should ask yourself if you would want to rebuild it at this time.
Old Nov 29, 2006 | 06:14 PM
B6T's Avatar
B6T
ERTW
But I don't want to rebuild it, I want to port it...
Old Nov 29, 2006 | 07:04 PM
diabolical1's Avatar
but you can't do one without the other. it has to be disassembled in order to port it, and therefore rebuilt when you get it back together. listen to what Aaron Cake said.
hotshot2014
Jul 18, 2017 02:30 PM
Skeese
65
Mar 28, 2017 03:30 PM
