Tire rack
Old Nov 28, 2006 | 05:42 AM
radiantRX-7's Avatar
Tire rack
I was looking at these BBS's What does everyone think?
They are like 20lb's each. Came out to 3,850 w. tires.
http://www.tirerack.com/servlet/Call...=&showRear=yes
Old Nov 28, 2006 | 10:25 AM
rynberg's Avatar
You can't post a link to your "garage" from Tire Rack....
Old Nov 28, 2006 | 02:08 PM
They are the BBS RGR 18X8 front and 18X10 rear. 19lb. each.They are showing the offset for the front +40mm and the rear is +42. I was looking on the thread for FD size's and it shows that the off set should be more then this.
Old Nov 28, 2006 | 02:23 PM
Mahjik's Avatar
Mr. Links
The front will fit, but you'll need to probably roll the fenders and run something like a 235 tire. As for the rear, the +42 should be fine with no additional modifications required.
Old Nov 28, 2006 | 09:42 PM
OK thanks Mahjik.
rx7jocke
72
Jun 17, 2016 03:48 AM
