Need Help with Noisy Throw Out Bearing
Old Mar 6, 2002 | 03:42 PM
Took the trans out, replaced 5th gear synchro, and put a NEW throwout bearing in because the old one was a little noisy... the new one is MUCH worse~ It gets better when it heats up, but is way too noisy when cold. I put grease on the contact points with the fork, and a little on the front (towards the front of the car) of the bearing, but couldn't tell where exactly the manual wanted it... these are sealed bearings right? How can I make it quiet???
I did not replace the pilot bearing because I did not have a puller for it. Mistake? Cause?
Also, though I marked and installed the driveshaft in the same orientation, I now have a bit of "gear" noise in reverse... ahh, help, I hate "fixing" my car only to have three new things wrong!
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Vartok
16
Oct 8, 2015 04:49 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
