SK Racing Carburetor
Old Nov 15, 2006 | 10:28 PM
Mechanic's Avatar
THE Mazdabator
Hello,
My friend has a SK racing carburetor, and would like to know if there is any websites that carry service parts for this type of carburetor, it is a side draft, looks very similar to a mikuni phh solex. The problem is, even at 3 psi of fuel, the carb floods out and "waterfalls" gasoline out of the two barrels and any other outlet including the hole above the "left" barrel (looking at the air horns directly).
Does anyone have a similar experience with any carburetor? If so, what may be wrong with the carburetor? Does anyone know where I can find service parts for this SK company? I cannot find it on google. Thanks.
I wasnt sure where to put this, but since the carburetor isn't stock, and probably was used in racing applications, I was hoping I can find some help here.
I thank anyone in advance if they can help me out.
Old Nov 16, 2006 | 05:06 PM
tims's Avatar
Weber carbs and there knock offs usually only need 2-4 psi of fuel pressure. parts are available but are tougher to find these days. look for companies that have weber parts they should be able to help.
Old Nov 16, 2006 | 05:42 PM
Siraniko's Avatar
RX for fun
Sticky needle & seat OR mis-adjusted float.
Old Nov 17, 2006 | 10:52 PM
Mechanic's Avatar
THE Mazdabator
hey guys, found one problem, dirt in the needle, but now that my friend cleaned it out and stuff (we also took off the top cover and cleaned out the inside) the carb doesnt squirt gasoline, but it doesnt leak, like nothing happens.
It's strange, we are too poor to buy anything else, so kinda stuck with this and have to work with it.
thanks guys, i appreciate the time you guys put into helping me out.
Old Nov 18, 2006 | 08:03 PM
Hyper4mance2k's Avatar
The Shadetree Project
http://www.webercarbsdirect.com/Webe...atalog_s/1.htm
http://www.pegasusautoracing.com/adv...=WEBERCARBNPTS
And read this
http://www.matthewnanney.com/images/Carb/
Old Dec 8, 2006 | 08:19 PM
rotaryisadorito's Avatar
I need help with this also I'm about to buy a car from a guy, and he tells me that the engine is running verry rich. Should I try to find smaller jets?
Old Dec 8, 2006 | 08:51 PM
680RWHP12A's Avatar
i have any part you need for that carb
the new version of that carb, same company different name is called oer
Old Dec 8, 2006 | 08:54 PM
680RWHP12A's Avatar
first find out your jet sizes , post them, then we can make some accurate suggestions as to what jet size for you to try ..
Old Dec 8, 2006 | 08:58 PM
ok, Im probly goin to pic the car up tomorrow. Then I will let ya know or I can ask him.
Old Dec 8, 2006 | 09:53 PM
Mechanic's Avatar
THE Mazdabator
how much is the gasket kit for the carburetor?
Old Dec 8, 2006 | 10:56 PM
Idk, I'm buying a car that allready has it on it. Thats why I need to look at it.
Old Dec 8, 2006 | 11:16 PM
It's the 4bbl holly carb
Old Dec 8, 2006 | 11:34 PM
680RWHP12A's Avatar
$68.00
Old Dec 9, 2006 | 10:10 AM
What kind of jets sould I get ? .40 or should I get the car first?
Old Dec 9, 2006 | 11:07 AM
680RWHP12A's Avatar
what jet size is in there now?
Old Dec 10, 2006 | 09:44 AM
Mechanic's Avatar
THE Mazdabator
What payment type do you take for the gasket kit?
and do you carry parts for a mikuni solex 44 ?
and if you do what jet size do you reccommend? I do not know the jet size on my mikuni, so I wonder what is good i currently run...
6port 13b removed 6port sleeve removed
racing beat manifold with old 6 port manifold (the center ports are smaller still deciding if it is worth going with the newer manifold...)
stock ports no porting
racing beat headers
oh yeah, and how much for the 44mm air horns..?? price for 2.
