Ignition: L1, L2, T1, T2, which goes where?
Old Nov 12, 2006 | 08:28 PM
sniperstevedave's Avatar
Dork
I changed my sparkplugs today, and now when I start the car the check engine light comes on. It seems to run, but I have a two hour drive ahead of me tonight and don't want to get stranded. I have tried switching the spark plug wires around, disconnecting the battery each time to reset the ecu, but the light comes on each time. So anyone have any ideas, and which rotor housing do L1 and T1 go to, and which housing do L2 and T2 go to.
Please help!
Old Nov 12, 2006 | 08:34 PM
Wizz's Avatar
Please help!
Front housing is #1 and rear is #2. Leading is Lower hole and Trailing is Top hole.
Ex. L2 = Rear Lower hole.
Old Nov 12, 2006 | 08:36 PM
Dork
Okay, tried that but the check engine light still came on. Anybody have any ideas as to why?
Old Nov 12, 2006 | 08:38 PM
myfc3s's Avatar
That's what she said...
Do you have the right plugs? put the old ones back on.
Old Nov 12, 2006 | 08:52 PM
Dork
The plugs are correct.
Old Nov 13, 2006 | 01:55 AM
NZConvertible's Avatar
I'm a boost creep...
Even if the plugs are connected wrong, this won't cause the CEL to come on. Something else is wrong. You need to check the ECU error codes to find out what:
http://www.johnr.com/cpucodes.html
NorthernForestMotorsports
Race Car Tech
44
Sep 23, 2015 07:18 PM
