no fuel?
Old Nov 12, 2006 | 01:34 PM
breckboarder55's Avatar
big port + big turbo=
no fuel?
So about two weeks ago i started relocating my battary, the fuel pump was wired directly off the battery. I rewired it to the battary harness; but when i went to start it after letting it sit it wouldnt start.
Every thing is hooked up and nothing else is altered. What could be the problem?
I currently have an fd pump...
Is there anywiring i could have pulled loose conected to the pump that passes through the fire wall underneath the dash?
thanks for the help
Old Nov 13, 2006 | 10:25 AM
Aaron Cake's Avatar
Engine, Not Motor
Since I clearly have a complete schematic of your wiring changes in front of me, I can tell you that the problem is.....
See where I'm going with this? It's hard to make a guess without knowing what you did to the wiring. So, does the fuel pump run when you try to start the car? What happens if you jumper it to 12V directly?
Sounds to me like the pump is wired wrong.
Old Nov 13, 2006 | 05:01 PM
i dont hear any pump wine... its wired directly off the battary, then goes through main fuses, then to pump. How do you jumper it to 12v directly?
thanks!
Old Nov 13, 2006 | 06:08 PM
fuse pulled loose? anyways i get her to run now!
thanks for the help
Old Nov 13, 2006 | 07:03 PM
drewl's Avatar
Flame Thrower
good goin man
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
