Removable sub box for FD..??
Old Mar 5, 2002 | 06:29 PM
yy4u's Avatar
Anyone with a removable box in an FD. I really want music in my FD, but i also do a lot of drag racing, and i'd like to try to stay around 2700 pounds on the dragstrip, Anyone with easily removable sub boxes? I know this makes me prone to theft, but thats not a big problem where i live. Any ideas. Maybe where the removable center piece is now, or in the spare tire well? THanks guys.
Old Mar 5, 2002 | 06:47 PM
7-sins's Avatar
thats not paint....
I would like to see one too.. maybe something that will fit 2 12's.
Old Mar 5, 2002 | 07:04 PM
HedgeHog's Avatar
Rotary Poseur
It's prolly not the ease of removal of the box that's the concern. You still have to consider all the connections - power, signal, speakers. They will have to be neatly dealt with. I guess you can get those XLR looking connectors like they use on demo board and make quick release connections. Otherwise, there'll be all those cable ends flopping about (definitely not a good idea).
WRT box, check out DamonB's box in this forum...looks very nice but will limit you to a low displacement 10".
Old Mar 5, 2002 | 09:04 PM
lils103r's Avatar
removable stereos
there are actualy realy cool subs with boxes and amps built in made spicificly for certain cars and trucks that use storage compartments. They are made by MTX, i highly doubt they make one for the rx-7 family (although that would be a blessing), but im sure you could always find a shop to build something similar. Possibly a lightweight box with just enough air to support the speaker, small amplifier mounted to it.
The connections on the other hand can be tricky, or very simple.. you basicly have 5 wires, signal imput, (usualy rca), battery, ground and last but not least REM (or turn on). as long as the rca's stay seperated you dont have to worry abou them. With the power wire is the fun part, either you can tape it up everytime you disconnect or use a simple approach that im trying with my truck box, use an inline fuse, much like the one off the battery. you can disconnect (unscrew) the cable from the fuse to the amp, pull out the fuse, and leave the connecter on the other side of the fuse in the weather proof holder (which is obviously no longer weather proof), found this works rather well, give you a few more inches or progection for the cable ends.
Just pull the cables off to the side and you're set.
Sorry if this post is extensivly long and full of grammer errors, i dont care about spelling and i am very long winded this evening.
Old Mar 6, 2002 | 07:25 AM
puma's Avatar
canadian monster
http://members.sounddomain.com/pumalex
my system takes exactly 7 minutes to remove from the trunk with two guys (because it is heavy)
puma
Old Mar 7, 2002 | 04:11 AM
yy4u's Avatar
I'm familiar with installations, and my plan is to have a box thats removable, not amp rack etc. I'll just disconnect the speaker wire. The bulk of the weight is the sub, magnet structure, and box. The amps dont' ad nearly as much weight, and like all of you said, there are a lot more wires involved. I think i'll end up doing a single 12 in a fiberglass box where the spare tire is. But i'm still thinking about vinyl covered fiberglass with 2 10's mounted inverted with magnets towards the seats, but it would be more difficiult to make that removeable.
BTW, puma thats a sweet install you have done, but i don't need quite the bass of 2 12's especially in such a small car.
Old Mar 7, 2002 | 08:50 AM
az_lynx's Avatar
I would have to agree.... 2 12's in an FD? ... now if they we're 2 crappy 12's w/ crappy amps... thats a different story. But trust me.... 1 12 w/ a correctly made airbox and the right amount of CLEAN power going to it would KILL!.... maybe an IDMAX (Image Dynamics) 12" w/ 1000 rms going to it! Yes... now that would shake the FD apart!
I was going to go w/ an IDMAX but I think I'm going to go w/ all Focal (Utopia) now. We're laying out the setup now. Looking at Helix for amps. *shrug* we'll see. It's a full custom job tho.... it's going to be a blast to build!
Old Mar 7, 2002 | 09:54 AM
bbeavers's Avatar
Sub Box
Outside of te JL audio sub enclosure that was made specifically for the FD and is no longer manufactured there is one that I think mighht be the perfect solution. Check out www.Elementenclosures.com
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
ZacMan
Sep 19, 2015 09:20 PM
risingsunroof82
Sep 7, 2015 01:11 PM
alemmons
Sep 4, 2015 09:34 AM
