Someone explain "exhaust scavaging"
Old Nov 7, 2006 | 09:11 PM
Whizbang's Avatar
Respecognize!
ive heard this term come up alot on other fourms when discussing manifold design for turbos. I have "ideas" as to what it is, but i really dont know.
Anyone care to enlighten me?
Old Nov 8, 2006 | 09:12 AM
Aaron Cake's Avatar
Engine, Not Motor
Exhaust scavenging is being able to use the exiting exhaust charge to either suck the exhaust out of the opposite rotor, or suck the intake charge into the engine via port overlap. Or both.
The key is to tune header diameter and length to time the pulses so that the the negative pressure created by one pulse will pull the exhaust discharge from the other rotor.
In the same sense, this is why high overlap ports (bridge, peripheral) work so well at high RPM. The exiting exhaust charge pulls in more of the intake charge. However this causes exhaust dilution at lower RPMs which can cause issues as well (low torque, poor idle, bucking, etc.).
Old Nov 8, 2006 | 07:09 PM
anewconvert's Avatar
Scavenging is MUCH more important in an N/A than a turbo exhaust. With a turbo the exhaust is under significant pressure and the pressure pulses get screwed up because of the turbo and everything converging at the turbo. Its more important to have everything come together as calmly as possible at the turbo than it is to worry baout scavenging.
In an NA scavenging can help to evacuate the exhaust from the engine, pull in the intake charge (increasing intake velocity), and reduce pumping loses.
BC
Old Nov 8, 2006 | 07:45 PM
13BT_RX3's Avatar
The General RE
I would say it is more of a delta P thing. Exhaust scavenging occurs only when intake pressure is high the exhaust pressure at the rotor/housing interface. The residual exhaust gas is displaced through the exhaust port by a higher pressure intake charge durring overlap. The effectivness of this scavenging directly effects the VE.
It is possible to have a turbocharger setup with more exhaust pressure than intake. No scavenging happening there.
A supercharger would be the best for exhaust scavenging. I want a supercharged PP.
Old Nov 8, 2006 | 11:49 PM
Exhaust scavenging doesnt occur because the intake is at a higher pressure, but the intake is at a higher pressure because of scavenging.
In a properly built header, at a given RPM, the exhaust pulses will reach the collector at the the correct time to cause the other primary to drop in pressure. This is what causes the intake to be at a 'relatively' higher pressure than the exhaust.
With a supercharger this effect is multiplied by the intake being under artifically higher pressure than the exhaust, which, with a tuned header, will also be under a relatively low pressure.
BC
rgordon1979
40
Mar 15, 2022 12:04 PM
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
