Is 15mm Spacer Will Fit ?
Old Nov 2, 2006 | 05:14 PM
jef57's Avatar
Unhappy Is 15mm Spacer Will Fit ?
15 MM SPACER WITH OEM RIMS ( offset 50) will fit rear fender on my FD?
Actually , i've bought H&R 5MM SPACER, is enough for rear fender with oem wheel?
IS H&R TRACK+ , lightest spacer?
I'm little affraid to put too big spacer on my car ( heavy)
Thanks for help
Old Nov 2, 2006 | 06:04 PM
xthephilx's Avatar
The stock wheels fit the rear fender. I don't get what you're trying to do.
Old Nov 2, 2006 | 06:36 PM
JTurtonRX_7's Avatar
EFR IWG 8374
coherent sentence please?
Old Nov 2, 2006 | 11:01 PM
Question
Hey, he's French, but him some slack
Jef57, why are you trying to use spacers?
Old Nov 3, 2006 | 01:00 AM
jef57's Avatar
Red face
HI,
i would to use spacer to enhanced appearance.
There is to much space on rear fender with oem wheel ( 16 X8 offset 50)
it's why i would use spacer....
Thank for you help
Old Nov 3, 2006 | 01:20 AM
rynberg's Avatar
Yes, 5mm or 15mm will work. Better to get bigger wheels/tires....
Old Nov 3, 2006 | 07:39 PM
Here are some pics of his beautiful FD that he emailed me, look at that paint
Attached Thumbnails Is 15mm Spacer Will Fit ?-dsc03174__640x480_.jpg   Is 15mm Spacer Will Fit ?-cimg0833__640x480_.jpg
Old Nov 3, 2006 | 09:18 PM
rynberg's Avatar
Very nice although I don't like body colored front lips....
Old Nov 5, 2006 | 02:30 PM
ARD T2's Avatar
So make sure you use longer studs for the spacers. An already studded 15mm spacer will not work with the stock FD wheels.
You must press in new longer studs.
Please keep that in mind. You can get away with a 20mm studded spacer that won't require any pressing of studs.
Rishie
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
