Stock wheel rubbing fender...can't figure why
Old Oct 29, 2006 | 04:51 PM
KungFuMonkey's Avatar
Good bye RX-7
Angry Stock wheel rubbing fender...can't figure why
When I had all stock suspension and stock wheels and tires the left front wheel would rub the inner fender lining. It would rub when I make a fast right turn with the weight shifting forward, and it would rub when I hit a divot driving on the highway. Now, there is a hole in the lining.
I've install bilstein shocks and tein springs; it helps a little because it lessen the body roll, but it would still rub. I though it would be the anti-sway bar or the mount, but I took apart and they looked fine(not bend, or cracked). The all suspension pieces of the right and left looked the same, but only the left side would rub.
I can't figure it out. I still have stock wheels and stock size tires.
Old Oct 30, 2006 | 09:31 PM
Good bye RX-7
I've also install brand new stock upper mounts also...
Old Nov 1, 2006 | 02:53 AM
Ottoman's Avatar
always modding
did u buy the car like this? or it happend on it own outta no where?
Hows the camber/castor/alignment/toe/etc?
bushings?
Old Nov 2, 2006 | 05:23 PM
Good bye RX-7
Yeah I bought the like that... After I get the aligment done, it would go out in less than a month. Which bushings? The ones in the control arms looked fine, what other ones are there that would contribute to that. I am going try to park that one side on the curb, and see if I can find anything wrong that way.
Old Nov 3, 2006 | 06:20 PM
NeoTuri's Avatar
The shy megalomaniac
- Nevermind -
immanuel__7
89
Sep 5, 2015 10:23 AM
