Will these fit?
Old Oct 25, 2006 | 01:24 PM
Lam_Clan's Avatar
Will these fit?
I found a guy locally with the following wheel size.
17x8+45
17x9+38
would these fit a TII without rubbing? Running Bilstein coilovers.
Old Oct 25, 2006 | 01:37 PM
neofreak's Avatar
accept no imitations™
nope
Old Oct 25, 2006 | 05:35 PM
Lam_Clan's Avatar
What is it about these wheels that don't make them fit? Is it the front offset? What if I use a 10mm spacer?
Old Oct 26, 2006 | 02:33 AM
RETed's Avatar
Rears no problem.
Even with the 10mm spacer, I think the fronts are still too tight - it might or might not fit.
1/2" spacer up front would work no problem.
-Ted
Old Oct 26, 2006 | 05:59 AM
87cncnu's Avatar
I'm runnin 17X7's with 225's and Bilsteins, and need a 3mm spacer to juuust clear the springs in the front. Don't forget. you may have to install longer studs if you space out much more than 6-8 mm.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
