What size wires?
Old Mar 4, 2002 | 10:40 AM
AreExSeven's Avatar
Huh?
What size wires?
rx7.com sells 10mm and 8.5mm magnacor spark plug wires. whats the difference (besides the obvious) and which one would I want to put on my car?
Old Mar 4, 2002 | 10:41 AM
RETed's Avatar
Boy, this got answer in another thread recently...
-Ted
Old Mar 4, 2002 | 02:40 PM
NZConvertible's Avatar
I'm a boost creep...
Re: What size wires?
From the Magnecor FAQ:
What gain, if any, will I get using 10mm size wires — compared to 8.5mm size wires?
Our R-100 (10mm) cable has a thicker insulating jacket, designed for extreme heat situations or where extra insulation is needed for extreme-output ignition systems and where it's not easy to space the wires from one another and/or the engine. Our KV85 (8.5mm) and R-100 (10mm) cables both use the same conductors and provide the same spark energy output, and, as most street and modified production engines don't really need a cable size larger than 8.5mm, using our 10mm size cable is usually overkill (or for appearance). Please understand our 10mm cables, due to their large diameter and bulk, will take more room, and a little longer to fit and loom correctly.
Old Mar 4, 2002 | 02:50 PM
UniqueTII's Avatar
Slow and old
What I like best about my 10mm wires are the reactions they get from anyone looking under the hood. The price was right, too.
Old Mar 11, 2002 | 04:31 PM
82mazdarx7's Avatar
Im Rick James Bitch
What I like about the 10 mm wires is that my car has 135 hp and with the 10 mm wires it bumps it up to a heeping 135 hp. I Can really tell the differance when I am racing my friend matt who has a turbo II.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
