car doesnt wanna stay running in gear
Old Sep 21, 2006 | 09:41 AM
i have an automatic transmission.and when i put it in to gear it wants to die. the only way it stays running is if i neutral drop it which i dont like. also if i take the choke off when its warmed up it doesnt wanna stay running. can somebody help me on this?
Old Sep 21, 2006 | 10:09 AM
perfect_circle's Avatar
do you let it warm up before you try and take off?? was the car running before this?? check around your emissions, and your intake manifold. it sounds like a vacuum leak. you can check for this by let it idle, then spray carb cleaner around. if the rpm's jump, theres your leak.
P.S. the vacuum leak would fix both problems.
Old Sep 21, 2006 | 10:18 AM
here. found this. https://www.rx7club.com/1st-generation-specific-1979-1985-18/wont-idle-w-o-choke-sudden-change-function-580046/
Old Sep 23, 2006 | 04:29 PM
thanks
Kyo
Apr 13, 2019 09:24 AM
rotor_veux
46
Jun 12, 2018 10:39 AM
meat_whistle
Aug 12, 2015 08:41 PM
Wolf_
Aug 11, 2015 04:23 PM
