Finally running!!!!!!
Old Feb 28, 2002 | 08:30 AM
NO VENOM's Avatar
few little problems guys.......
Starts with no problem but on an idle it kinda skips a beat and hunts.?
second I can only get 9 lbs of boost and cuts out,it feels like running out of gas.
Tahnks
Gil
Old Feb 28, 2002 | 12:10 PM
Bucrx7's Avatar
If your exhaust sounds like it's skipping it's fine as long as your idle is solid around 750-850. Now about the cut out on 9lb, is your boost gauge accurate? It sounds like you are hitting fuel cut. Try to run the car around 7-8 pounds and see how it runs. It can also be an ignition problem under high boost, my car use to sputter and not felt like it cut at full boost. After I change my plugs and wires, it felt like a new car.
alphawolff
Nov 17, 2015 05:57 PM
