No fcd; will i hit fuel cut?
Old Sep 18, 2006 | 06:57 AM
rx7 SE's Avatar
Enthusiast
Yesterday i installed a 91 TII exhaust on my 87 TII. I gutted the cat and now everything is running awesome besides the bad exhaust smell. But i didn't switch the downpipes because the one on the 91 has no precat on it and mine does. I figured that i would probably hit fuel cut with that downpipe. Am I right?
Old Sep 18, 2006 | 08:14 AM
riverzendz's Avatar
Interruptor Illuminada
More than likely.
Old Sep 18, 2006 | 08:16 AM
R_PROWESS's Avatar
F[x]3S ENG.
ya theres a good posability, you might want to port the waste gate
Old Sep 18, 2006 | 02:46 PM
bacek's Avatar
what are your other mods?
i dont think you will since you still have the precat in place and since the exhaust system itself from any stock exhaust isnt that free flowing... but then again it really depends on your mods.
Old Sep 18, 2006 | 05:13 PM
rx7 SE's Avatar
Enthusiast
Removed air pump, ac, catalytic converter, and bomez air filter
Old Sep 18, 2006 | 05:53 PM
Boostmaniac's Avatar
www.corksport.com
Go buy their down pipe and mid pipe. Real nice stuff.
Just make sure to get an FCD and to port the crap out of your wastegate. Or you could swap to an S5 turbo manifold and turbo. That might make it easier for you.
Anyways, the above mods are good for some real power gain.
Old Sep 18, 2006 | 06:13 PM
bacek's Avatar
^hes not asking that......
oh and is it a "cai" or just the filter in the stock airbox
if its a real cai or a rx7 "cai" then you will hit fuel cut without a fcd.. if its a filter in the stock airbox you probably wont as long as you have a precat, cat, and s5 exhaust you probably wont since your not really opening up the exhaust and intake. the stock intake helps keep boost down, and since you dont have a free flowing exhaust you should be safe
but i said probably... if i were you i would make sure i do everything safe but thats not the question youre asking
Old Sep 19, 2006 | 07:12 AM
rx7 SE's Avatar
Enthusiast
Alright, so if i installed the fcd would there be boost creep? Is there an easy (cheap) way to keep that from happening.....like porting the wastegate. Oh and i have a cai
Old Sep 22, 2006 | 07:24 AM
rx7 SE's Avatar
Enthusiast
Alright, so here's another question. Would i need to buy a new fuel pump or upgrade the injectors to coincide with this new downpipe?
Old Sep 22, 2006 | 11:21 AM
J-Rat's Avatar
Alcohol Fueled!
Only if you plan on running lots-o-boost!
Old Sep 23, 2006 | 09:26 AM
rx7 SE's Avatar
Enthusiast
nope, the only reason i'm really putting it on is because it's just sitting in the back of my se and i'm a little curious on how it will sound with it on. Besides that i'll be keeping everything stock
Microtech
30
Apr 23, 2016 06:37 PM
Snook
21
Sep 1, 2015 06:32 PM
armans
Aug 15, 2015 09:08 PM
