engine giving problems still
Old Sep 13, 2006 | 11:00 PM
R_PROWESS's Avatar
F[x]3S ENG.
I'm backfiring during free rev around ~4k rpm so bad i think the exhaust might blow off.. i think i can pass it if i rev it quick enough though. i've seen the threads with people with similar symptoms and didn't see how it was cured. I cant drive my car worth crap and ive changed my tps and map sensor and timing is right. injectors are brand new and so is fuel filter. i have the stock turbo II pump. so I dont think it's a fuel problem, how could i be going lean in free rev? would it be my spark cuting out instead?
Old Sep 13, 2006 | 11:21 PM
locketine's Avatar
Road Rotary Aviator
backfiring is from going rich, not lean. You could be having spark problems or something could be wrong with ur fuel metering system. Possibly even a vacume leak.
Old Sep 14, 2006 | 02:38 PM
R_PROWESS's Avatar
F[x]3S ENG.
you were right i did have a vaccum leak and stil do to a point i havent had time to track it very good but it doesnt bog anymore and is smooth through the rpms in nutral but in 2nd if i put too much load on it it cuts out sometimes but ill get it fixed
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
