Sponsored by: CARiD
Electrical problem
Old Aug 27, 2006 | 06:38 PM
1.3V8KILLER's Avatar
Electrical problem
I just put in a newly rebuilt motor on my FD. When i put the batt in i had a couple of electrical systems that did not work, meanwhile i had a couple of systems that did work.
Systems that work:
Dash lights
Parking lights
horn
Blinkers
door locks
Systems that don't work:
Starter
ECU
Headlights
Fuel pump???
Window Regulators
I have already gone through and re-done all of the grounds that attach to the motor as well as the body(3 under ratsnest, one on drivers side of motor, one under fuse\relay blocks, one from uim to fire wall). I have also used some 4 gauage cable to add some more body and motor grounds. I was wondering if any one had delt with this before or if any one had any ideas. I have already checked all of the fuses and they are all ok. I am ready to.....well i will leave that up to you. As usual all help is appriciated. Thanks.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
