Canadian Forum Canadian users, post event and club info here.
wideband needed in ottawa
Old Aug 26, 2006 | 08:48 PM
nfs05's Avatar
RB all the way
hey guys i just installed my safcII, i was just wondering if anybody had a wideband 02 sensor i could borow for a bit for tuning,
Thanks
Old Aug 26, 2006 | 09:49 PM
rx_prez's Avatar
got paint?
I have one that i just bought from Azad but installed in my car as a guage and is not that easy to remove. I know Nik used to have one that was alot easier to remove and install. If you cant find one to use then sometime after cayuga I can take mine out and you can use it.
Dave
Old Aug 29, 2006 | 10:47 PM
FC3S.USD's Avatar
Where is my Life ?
The best would actually go to a dyno and get it horsepower tuned.
A given afr wont give you max hp. and I dont think the butt dyno will tell you if you gained that 5-15 hp.
Tapp Auto Dyno tune for max hp is $ 120-$ 160 ( thats with Chriss tunning AFR and MAX HP ).
Probably the best option.
Old Aug 29, 2006 | 11:30 PM
coldfire's Avatar
ERTW
Yeah, my wideband wiring harness is actually soldered into the main harness, so not so easy to remove unfortunately.
if you actually want a wideband for yourself, the Zeitronix ZT-2 is a good priced option.
but if you just want it tuned once and then forget about it, taking it to the dyno would be the best thing to do.
but, before you go make sure you do a little research as to what general AFRs are good, and then tune from there. a little safety margin is good because the stock ECU i have noticed is not very consistent with AFRs...but, NA is not so much an issue as a forced-induced rotary. i have hit ~14.0 at WOT and nothing bad happened.
i can give you my SAFC corrections as a guideline maybe, but those will just be a ballpark of what you will need.
Old Aug 30, 2006 | 05:24 PM
FC3S.USD's Avatar
Where is my Life ?
Theres not that much info for AFR on NA, thats and most turbo guys tune for safeness.
With NA I think that you can play around with the afr for max horsepower.
Chriss knows the SAFC like the back of his hand, so for the hour of tune hell do a very good job.
Old Aug 30, 2006 | 07:23 PM
coldfire's Avatar
ERTW
yup, just saying the stock ECU is wierd i have found. it does different things on different days, depending on what if feels like doing, haha. i'll have it tuned nicely, then the next day i see it is off by 0.5 AFR in some places.
but yeah, taking it to a place like Tapp auto is a good choice if you want to go that way.
Old Aug 30, 2006 | 08:55 PM
nfs05's Avatar
RB all the way
right now i have no money for dyno time, and i have a good understanding of what afrs are needed for power... so i was just wondering if i can borow one for a couple nights of tuning, if i cant i'll just wait till next year and dyno it
Old Aug 31, 2006 | 01:26 PM
nik's Avatar
nik
Jay you can use mine, but it's in the race car right now. Next time I go out there i'll pick it up.
