Megasquirt Rotary Specific MSI V3.0 Info
Old Aug 24, 2006 | 11:21 PM
Jobro's Avatar
SAE Junkie
Hey
U I've started assembling my MSI for use with my 12a extend port.
I'm lost as to what things I need to modify on the board for use with the Msns-Extra and for the ignition output. I'm going to mod the cas and use the single VR conditioner provided.
I remember reading somewhere on here I needed to use different transistors or something. Can anyone help me out, I thought this would be allready covered but I can't find it. Maybe not many mods are needed :S
I'm using external ignitors also.
What Method for Idle control can I use?
Is there a sort of closed up idle control that uses the tach wire and keeps it sufficiently high?
Old Aug 25, 2006 | 08:56 AM
muythaibxr's Avatar
MegaSquirt Mod
All the necessary mods are listed in the FAQ thread in this section. When you get to software configuration the screenshots are a bit old (I plan on fixing that soon).
The1Sun
Mar 18, 2018 11:08 PM
1993fd3sracer1
Aug 31, 2015 07:14 PM
elfking
Aug 19, 2015 09:48 PM
