Megasquirt building ms v3 2nd vr circuit
Old Aug 21, 2006 | 11:12 PM
microvio's Avatar
Question building ms v3 2nd vr circuit
hello im building my ms v3 and im not too skiled on electronics and im confused whit this diagram of the dual vr circuit becose im not sure what parts to buy.
i know i have to build only the right part of the diagram according the ms rotary FAQ
so affter having a crash curse reading on electronics i figure i have to do this
2 leg on lm1815 to ground
3 leg on lm 1815 to 330pF capacitor taht goes to ground, and before connects to the 330pf capacitor a 18k resistor taht connects to G+ on the cas
7 leg on lm1815 to a 0.33 (dont know waht this part is) taht goes to ground
7 leg on lm1815 also to a 1M resistor taht goes to ground
8 leg on lm1815 not sure if i should wire it to +5v directly or to a 56k resistor and then to 0.001 capacitor taht goes to ground
9 & 11 leg on lm1815 to the same ground
12 leg on lm1815 to a 4.7k resistor that goes to +5v, and connect before 4.7k resistor a cable that goes to pin 11 on the CPU
14 leg on lm1815 to a 82k resistor taht goes to +5v, before the 82k resistor a 0.01 capacitor to ground
and G- form the cas to any ground on the lm1815
sorry if my speeling is wrong inglish is not my native language, and my inglish is a quite learned
