T6 flanged turbo trims
Old Aug 15, 2006 | 11:33 AM
red_ricer's Avatar
Spending too much $$$
I am trying to figure out which trim my huge fricken turbo is so I can get a different turbine side for it and preferably something that has a T4 flange. Where can I find out trim specs on a T6 flanged turbo?
Old Aug 15, 2006 | 11:51 AM
Zero R's Avatar
Just in time to die
Way too vague a question. T6 could be on any number of different turbo's.
-S-
Old Aug 15, 2006 | 06:48 PM
red_ricer's Avatar
t6 flanged....1.32 a/r hotside 3.640 minor wheel dia. 4.025 major wheel dia. , and .70 a/r compressor with a 55 trim.
Old Aug 15, 2006 | 07:22 PM
Zero R's Avatar
Just in time to die
If this is turbine and your exducer is 92.456mm as stated and your inducer is 102.235mm as stated your trim is 82. That's all the free help you get That is a pretty good sized turbine. I have a few here slightly larger.
-S-
Old Aug 16, 2006 | 10:45 AM
red_ricer's Avatar
You have several larger ones? What are you running them monsters on?
Old Aug 16, 2006 | 02:28 PM
Zero R's Avatar
Just in time to die
One is sold, I have no idea what they intend to put it on, the other is going on a car I'm building here for a customer.
-S-
Old Aug 17, 2006 | 07:55 PM
3rotorGTU's Avatar
20B FTW!
the problem is going to be finding a t4 turbine housing desigend to fit on a CHRA desgined for a t6 housing.
a t6 based CHRA uses a much larger mating surface than any t4 housing could provide. i looked into doing the same thing but quickly gave up. even with my buddy who builds custom turbos couldnt help me
