low idle when clutch engaged
Old Aug 7, 2006 | 04:56 AM
revmeuprx7's Avatar
Hello all,
I have a question or actually wondering if anyone knows about a problem i have been having with my FD. When I am driving either on the street or the freeway i get a very low drop in RPM all the way down to about 500 when i engaged the clutch to brake. Sometimes it idles slowy down to 900 where it normall idles at but then sometimes it will drop kind of faster than normal down to about 500 and then slowy climb back up to 900. Anyone have an idea? Do i have bad electical or is it something with my motor? Any suggestions or related ideas would be helpful,
Thanks.
Old Aug 7, 2006 | 12:45 PM
Bad_Karma7's Avatar
7th heaven
Clutch switch
Old Aug 7, 2006 | 03:16 PM
neopj3's Avatar
tps might need to be adjusted. also check your ground points.
Old Aug 9, 2006 | 05:32 PM
revmeuprx7's Avatar
well i took it in about a month ago and had all new grounds so i don't think its that, what should i do with the clutch switch. Not to be ignorant but I am not familiar with TPS, do you mind explaining and what i need to do. Thank you for the help guys.
Old Aug 10, 2006 | 05:36 AM
Rated R1's Avatar
Oji San
Do you have a Power FC by chance? I am going with Bad_Karma7 here. I think it is the clutch switch.
Old Aug 11, 2006 | 01:11 AM
revmeuprx7's Avatar
I have haltech, if that makes a difference. But I mean i dont know what else it could be. maybe a bad battery? When the idle drops low when i engage clutch the dashboard lights will dim a little bit. Hmmm.
Old Aug 11, 2006 | 09:49 AM
RXtacy's Avatar
I'm the Juggernaut BITCH!
I'll 3rd the clutch switch... just replace it theyre like 20 bucks from ray.
Old Aug 13, 2006 | 06:36 PM
revmeuprx7's Avatar
thanks a lot guys going to go do that today.
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Kruel13
Aug 26, 2015 12:17 PM
