will a 20b metal front cover gasket work on a 13bt?
Old Aug 3, 2006 | 10:58 PM
Node's Avatar
just like the title says.
yes?
no?
Old Aug 3, 2006 | 11:42 PM
Jeff20B's Avatar
Lapping = Fapping
lol, what makes you think it's metal?
Old Aug 4, 2006 | 12:55 AM
Node's Avatar
a little birdy told me. Could I have dislexified what they told me?
I'm pretty sure it was the front cover gasket, but dunno.
Old Aug 4, 2006 | 03:44 AM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
not metal.
Old Aug 4, 2006 | 01:19 PM
Jeff20B's Avatar
Lapping = Fapping
It's the same paper material as used on 13Bs etc. I should know because it sucked scraping it off.
Old Aug 4, 2006 | 01:33 PM
Merovingeon
Veteran: Air Force
me too X10
Old Aug 4, 2006 | 02:34 PM
j9fd3s's Avatar
Community Builder
the rx8 gasket is metal, and works, with a little trimming. the newer engines have the metal gasket and no spot for the o-ring. earlier engines have the o ring and paper gasket.
you can use the metal gasket on an o ringed engine but you still need the o ring
Old Aug 4, 2006 | 03:04 PM
mcfly's Avatar
is it a issue using the paper one?
Old Aug 4, 2006 | 09:53 PM
GtoRx7's Avatar
Collections Hold
Mazda comp sells metal versions of both the FC/20B and the FD front cover gaskets. Very nice I must say, no trimming needed.
Old Aug 17, 2006 | 02:34 AM
AlamoAutosports's Avatar
Originally Posted by onefastrx7turbo
not metal.
My 20B D507 has a metal one, I just saw that today. All my 13B REs had paper gaskets though.
Old Aug 17, 2006 | 03:50 AM
glenrx7's Avatar
Building my car...
Mazda Comp sells a 20b gasket that is metal. Picture has the gasket that I ordered, it is indeed metal and fits 13rew for sure.
Attached Thumbnails will a 20b metal front cover gasket work on a 13bt?-20bfc.jpg
Old Aug 17, 2006 | 03:57 AM
Merovingeon
Veteran: Air Force
mine came with a paper one, I didnt know mazdaspeed was making aftermarket ones?
Old Aug 17, 2006 | 01:20 PM
j9fd3s's Avatar
Community Builder
they arent. sometime after 95 they switched from papre to metal.
Old Aug 17, 2006 | 01:23 PM
glenrx7's Avatar
Building my car...
Red face
Well here is the thing, you are not incorrect. They came with a paper gasket just like the third gen came with paper intake gaskets, yet when replacing these said gaskets they are now metal. Most gaskets on anything in the mid 90's has been replaced with metal with exceptions.
Mazda is like a water head when it comes to this, they have these metal gaskets for the 20b, yet if you order for a third gen or second gen s5 they are still paper, however the 20b gasket is identical, and cheaper
Sorry I did not explain this in the last post.......It was like 1:30 and I just got home from the shop.
Glen Weaver
www.azrotaryrockets.com
info@azrotaryrockets.com
Glenrx7@gmail.com
astrum
24
Nov 15, 2017 08:44 AM
morataya
Microtech
Aug 17, 2015 01:04 PM
