Ground Control Advanced Design coil-overs eye candy
Old Aug 2, 2006 | 02:17 AM
o0Dan0o's Avatar
I have a few pictures of the Ground Control AD coil-overs I just received and I thought I would share. Before anyone asks, the car is in the middle of the build and I probably won’t have any driving opinions of them for a while, and even then I have hardly driven stock RX7’s so I wouldn’t be able to compare (sorry)… They are double adjustable mono-tubes, spherical bearings (pillow ball) top and bottom on the front and top on the back (since the bottom merely bolts to the control arm). The rear springs seem (I haven’t measured) to be slight larger diameter than the fronts (probably 2.5” rear and 2.25” front), this is fine with me although I am curious as to why they did it that way. Build quality seems top notch, although I won’t know that for sure until I get a few laps on them. Anyway, enjoy if you like this sort of thing!
Dan
Attached Thumbnails Ground Control Advanced Design coil-overs eye candy-picture-0281.jpg   Ground Control Advanced Design coil-overs eye candy-picture-0291.jpg   Ground Control Advanced Design coil-overs eye candy-picture-0301.jpg   Ground Control Advanced Design coil-overs eye candy-picture-0311.jpg   Ground Control Advanced Design coil-overs eye candy-picture-0321.jpg
Old Aug 2, 2006 | 03:13 AM
maxcooper's Avatar
WWFSMD
Looks good. It is nice that they come with fresh bump stops. Bump stops are important, and I don't recall seeing them on many other coil-overs (though maybe it is just that they are black on other units or something ).
-Max
Old Aug 2, 2006 | 09:03 PM
Mindspin311's Avatar
Powered By Trochoids
Price? Spring rates?
Old Aug 2, 2006 | 11:14 PM
Black91n/a's Avatar
Those look like the springs seen on this page: http://www.negative-camber.org/crisp...c/fcpart29.htm
Old Aug 2, 2006 | 11:15 PM
Trout2's Avatar
You'll need to find some 4x4 shock boots to keep trash from making it past the piston seal. My AD's had to be rebuilt after 18,000 miles of street driving. When I get home next week, I'll post up the part nos. for shock boots from Summit that work.
I didn't know they offered pillow ball mounts. Mine have rubber bushings that wear out pretty fast. I'll be calling to check on those soon.
As for the spring diameter, mine are 2-1/2 in. F&R. Standard Eibach ERS springs. I started with 550/450 F/R and moved to 450/375 F/R, it puts the power down much better with the softer rear. I wouldn't mind going a little softer, like 350 or 325 on the rear. Can't go any softer on the front or my 255/35/18's would be rubbing.
Jack
Old Aug 3, 2006 | 12:33 AM
o0Dan0o's Avatar
They were $2,210 to my door. I called ground control and they say the rears are listed as 2.5” ID springs, although they are obviously of a greater OD. The front springs are also 2.5” ID (as the serial printed on them states). I chose to go with 650 lb/in fronts and 550 lb/in rears, which gives me a good range of adjustability in terms of spring rates. I plan on running 285’s on all fours, which is why I chose higher rates, and after playing with front and rear sway bars I will adjust the rates to suite.
As for the dust boots, that is a good idea although this isn’t a street car and probably wont see more than 10k before I want to rebuild them to adjust for new spring rates anyway. On the other hand, better safe than sorry! I would greatly appreciate the links.
When I first called they said they didn’t use spherical bearings, but they do now apparently. The difference in performance is probably very little, but I would imagine that the lifetime would be better in a track car.
Dan
Old Aug 3, 2006 | 12:51 AM
2a+RoN's Avatar
Looking good. I picked up a rebuilt set a few months back that came with 10 springs! So if you decide to go with some different spring rates, let me know..
Old Aug 3, 2006 | 02:38 PM
ptrhahn's Avatar
AFAIK, the mounts are just GC units. How does that upper bushing wear out, mine's been on there for years? All it does is locate the upper shock shaft.
[QUOTE=Trout2I didn't know they offered pillow ball mounts. Mine have rubber bushings that wear out pretty fast. I'll be calling to check on those soon.
[/QUOTE]
Old Aug 3, 2006 | 10:23 PM
Trout2's Avatar
[QUOTE=ptrhahn]AFAIK, the mounts are just GC units. How does that upper bushing wear out, mine's been on there for years? All it does is locate the upper shock shaft.
The mounts consists of a lower washer, lower rubber bushing, mounting plate, upper rubber bushing, upper washer, small spacer, then two nuts. That small spacer has a smaller diameter than the hole in the mounting plate so the spacer wore into the top washer until the shock's shaft could move around and wear away at the rubber. I have pictures that better show what happen but don't know how to resize the pics for posting.
Jack
Old Aug 3, 2006 | 10:32 PM
o0Dan0o's Avatar
Open the picture in paint, hit ctl+W, there you can resize the image by %. If ctl+W doesn't work, click on "image" (three to the right of "file"), then on strech/skew... and thats the same window. To chose the amount you need to reduce the image just devide the maximum file size by the current file size and thats your %.
Dan
Old Aug 7, 2006 | 12:57 PM
Rx_treme's Avatar
I cant wait to get mine!
Dan how much does your FD way?
Old Aug 9, 2006 | 01:13 PM
o0Dan0o's Avatar
Dunno yet, doesn't have the roll cage in it yet (or an exhaust, or a drive shaft, or a suspension yet, or a host of other things... Damn not having enough time to work on the project!!)
Dan
Old Aug 11, 2006 | 10:53 PM
Trout2's Avatar
Here are the pics of what happened to the front shock mounts. I will be contacting GC to see about ordering pillow ball mounts, hopefully they'll sell the bearing and let me modify my mounts versus buying four whole mounts.
Attached Thumbnails Ground Control Advanced Design coil-overs eye candy-000_0357reduced.jpg   Ground Control Advanced Design coil-overs eye candy-000_0358reduced.jpg
Old Aug 11, 2006 | 10:55 PM
o0Dan0o's Avatar
That looks pretty nasty...
Old Aug 16, 2006 | 03:13 PM
melicha8's Avatar
Mazdaspeeding
I had some coilovers from GC and they did that too. I don't think they use quality aluminum.
Old Aug 17, 2006 | 10:20 AM
2a+RoN's Avatar
that doesn't make me feel so good to know.
Old Aug 17, 2006 | 06:40 PM
Trout2's Avatar
It happens slowly so you can watch the top washer from under the hood and see if it's getting distorted. Unfortunately. I wasn't watching closely until I could feel the shock move through the steering wheel.
I spoke with Jay at GC yesterday, he said they will warranty the bushings if they wear out (which was my experience a few years ago). There are actually black urethane bushings. He was surprised mine wore out and asked me to send pictures that show the problem I described with the spacer eating into the top washer.
On another note, the reason I called GC was to ask about the pillow ball mounts. Jay came to the phone to say they strong recommend against them on a street driven car due to noise. He said all pillow ball mounts make noise (this hasn't been my experience, though).
For those wanting to upgrade to the pillow *****, they use a different top plate so you can't modify your existing mounts to hold the spherical bearing. Cost for each is $60 for mount with pillow ball and $37 for just the spherical brg.
Jack
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
rx7shirley
Sep 2, 2015 02:11 PM
