What are your wheel sizes/ offset w/FEED fenders?
Old Jul 25, 2006 | 04:19 AM
RX72NR's Avatar
paying to play
I'm gonna be putting in an order for some custom wheels and don't have the Feed fr/rear fenders yet. Post any pics along with the set-up measurements please. Also mention if you had to modify the stock rear fender and if you lowered your FD.
THANKS!
Attached Thumbnails What are your wheel sizes/ offset w/FEED fenders?-feed-front.jpg
Old Jul 25, 2006 | 01:06 PM
Farhan's Avatar
RSPECT
I honestly think your best bet would be to contact FEED directly and ask them what size/offset they used for the car pictured above. I LOVE that car BTW .
Old Jul 25, 2006 | 10:42 PM
13bmaniac's Avatar
i ordered recently a wide body kit fro my fd3s rx7 the vertex ridge was my final call, but i was also considering the feed rear and front fenders before acording to her website they dont recomeded nothing under 9 inch wide to the front and 9.5 inches to the rear ,also they said to me that according to wheel brand and offset may vary.the vertex wide body is very similar is only 5 mm wider than the feed rear flares in the rear and exactly the same in the front 35mm.
this is my set up that according to Brian Duong at mackin will be the best i can get:
i will be running 18x10 gram lights 57s-pro in the rear and 18x8 in the front
18x9.0 +5 using A disk for caliper clearance (69.3mm lip)
18x10.0 +/- 0 offset using C disk (stock rear caliper is pretty small)
will have 107mm lip.
i thing ill go with the -0 offset so i get a bigger lip.
and running 295 bf goodrcih t/a drag radials
hopoe this help
Old Jul 25, 2006 | 10:50 PM
13bmaniac's Avatar
pics:
all this cars are running 18x10 wheels with close to - offsets
te first is the vertex on the apex car and the blue car is with feed rear flares
Attached Thumbnails What are your wheel sizes/ offset w/FEED fenders?-apex_test_day_3_1.jpg   What are your wheel sizes/ offset w/FEED fenders?-dcp04180.jpg   What are your wheel sizes/ offset w/FEED fenders?-dcp04168.jpg
MILOS7
Aug 19, 2015 07:25 AM
