What order to bleed brakes
Old Jul 23, 2006 | 11:45 AM
freq's Avatar
I've got an S4 TII with ABS.
In what order should I bleed the brakes?
Old Jul 23, 2006 | 12:15 PM
turbo80cid's Avatar
start at the right rear, left rear, right front, left front.
Old Jul 23, 2006 | 12:16 PM
311unity13B's Avatar
That's JDM tight, yo
yeah, you start from the farthest away from the booster and go to the closest
unless you have a electronic brake booster like i do at work, you hook up all hoses to the valves and a hose to the booster reservouir and press start and it literally takes less than 5 min to suck system dry, replace fluid, and bleed it automatically. its freaking awesome
Old Jul 23, 2006 | 01:31 PM
turbo80cid's Avatar
that would be cool....it takes forever to do it the old fashion way.
Old Jul 23, 2006 | 02:00 PM
tinvestor's Avatar
the way I like to do it is buy 4, 1 man bleeders they are available at most auto parts stores just fill the cups above the bottom hose in each cup and top off the master cylinder then open all 4 bleeders and pump about 10 times then refill mater repeat refill repeat by this time the cups will be near full and the brake fluid will be all new!
Old Jul 23, 2006 | 02:24 PM
Boostmaniac's Avatar
wow, I kind of understand you but not really.
Old Jul 24, 2006 | 03:45 PM
tinvestor's Avatar
I guess you would need to see the bleeder cups. to understand fully. I looked for them at Advance and they didnt have any but most parts stores will.
Old Jul 24, 2006 | 04:02 PM
Integral's Avatar
Turbo Punk
^^^ that's essentially what i do, except w/ 1 cup at a time :P
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
tonka_1956
Sep 2, 2015 05:55 PM
