Engine install woes.
Old Jul 22, 2006 | 03:27 PM
Ril_Silver's Avatar
I got a brand new engine built for me and did the install myself, now I can't get the damn thing to start up. It cranks like it wants too, but I can't get it to fully turn over and run. If starter fluid is used then I can get it to go for a little bit before dying out. My friend and I think its a computer management issue.
After popping a plug the front rotor was a little gas heavy, while the rear was fine. We swapped injectors to test to see if one was just stuck open, and the same thing happend with the front rotor. When the plugs were removed we'd get little puffs of gas out of the plugs but not in the rear rotor.
When we try to use the jumper to 'prime' the fuel system it keep running and dosen't stop 'priming'. We can't discover a leak in the fuel system and we aren't sure if its just dumping into the engine. The damn thing wants to start but we can't get it too. Any theories or ideas out there? Any help or leads we can get would be most appriceated.
Old Jul 22, 2006 | 03:36 PM
RotaryEvolution's Avatar
Sharp Claws
pull the injector clips off and inspect them, i am willing to bet one of the pins is pushed back in the connector so you are only getting fuel to one rotor.
Old Jul 22, 2006 | 04:50 PM
Ril_Silver's Avatar
Complete
Well one of the pins was recessed like you said it would be. I pulled it apart and put it back togather, I had to play with its polarity since I forgot how it was origionally wired. In any event its closer to starting, and i get it to almost launch, but it dies out again.
Old Jul 22, 2006 | 05:41 PM
1SxyRXy's Avatar
my fc broke
check for maf leaks. the polarity on the injectors doesnt matter they are non polar
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
