NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
VA State inspection - emissions FD friendly
Old Jun 8, 2006 | 10:35 AM
Nuvolari's Avatar
Veni, Vidi, Vici
Ok, I am not expecting a response on the thread, just PM me if you can help.
I had a tech but hes moved. I need my single turbo FD inspected and emissions tested. Its cool on the saftey side but its a joke with emissions. If you know of a shop or tech in the Northern Va area thats cool PM me.
I figure its going to cost a little $$$ but it beats bolting the old crap on just to take it off after emissions.
Old Jun 13, 2006 | 10:24 AM
Nuvolari's Avatar
Veni, Vidi, Vici
No luck so far, I hit one shop In Manassas and got screwed over bad. Any ideas ?
Old Jun 13, 2006 | 11:57 AM
Brent 94's Avatar
It's hard to find a shop unless you know someone that works there. Some shops send people around to all their locations to ask if they can be passed (to try and catch bad testers), so techs are very cautions about it. Good luck, I've got another year before i have to go through that crap again.
Old Jun 13, 2006 | 05:18 PM
FDNewbie's Avatar
Sponsor
Yea it's getting REAL tight nowadays...
Old Jun 15, 2006 | 03:08 PM
Nuvolari's Avatar
Veni, Vidi, Vici
I think its my FD getting even with me. I let her sit for almost two years, now its running like a champ I cant drive it. Nothing like owning a 400+ hp car and not being able to go for a spin
Virginia is a police state... and it sucks ***.
Old Jun 15, 2006 | 03:16 PM
Nghtstlkr7's Avatar
Living on Borrowed Time
ive got the same issue... been on CA tags forEVER and i just want to get the emissions done and overwith. im not too sure if i'll pass though b/c of my intake and porting. as for a cat, im still on the lookout for one that i can easily afford.
id rather just get "passed", but that doesnt seem likely.
Old Jun 15, 2006 | 03:38 PM
tjeter's Avatar
I'm going through the same thing, my tags are dead, and i need to get my emissions done. I think i found a friend though.
Old Jun 16, 2006 | 06:59 AM
KNONFS's Avatar
B O R I C U A
Why won't your car pass the e-test? are you running a BP?
I got mine on August, and I am not looking foward to it
Old Jun 16, 2006 | 08:35 AM
Nuvolari's Avatar
Veni, Vidi, Vici
Why...lamo. The top of the list, no air bag, no cat, no air pump. And there is no way in hell I am messing with my set up right now. After two years of build up, I refuse to tear it down again. I still have a few options, but its very inconvient.
Old Jun 16, 2006 | 08:37 AM
ptrhahn's Avatar
I'd just work on retrofitting the equipment. If you've got a good factory maincat, and an airpump (either factory or GM electric) feeding it air, you should pass the dyno test. Might as well set it up now, so you don't have to go through this ever two years.
Old Jun 16, 2006 | 11:59 AM
KNONFS's Avatar
B O R I C U A
Exactly, that's what I did last year (then again I am nowhere the 400hp mark, yet). Once the cat and air pump is installed, I am sure he can get a custom map just for e test days...
Old Jun 16, 2006 | 12:34 PM
ptrhahn's Avatar
I didn't even need a custom map. I passed by a mile set on 11-12 psi.
Old Jun 16, 2006 | 01:48 PM
KNONFS's Avatar
B O R I C U A
Stock cat?
Old Jun 16, 2006 | 02:44 PM
niburu's Avatar
you can legally remove the airbag in the state of VA as long as you also disconnect the airbag system indication light in the dash as well
glad I don't have to deal with emissions here central VA
Old Jun 16, 2006 | 03:04 PM
ptrhahn's Avatar
Stock cat.
Originally Posted by KNONFS
Stock cat?
Old Jun 16, 2006 | 04:08 PM
KNONFS's Avatar
B O R I C U A
Stock cat.
Good to know, I had "issues" with the magnaflow high flow cat, meaning I had to adjust the map and run D-Alcohol; it passed non the less
Old Jun 17, 2006 | 08:17 AM
turbodrx7's Avatar
PURIST
Well there is one other way out...if you have coilovers drop the car as low as it will go...if its to low they cant get it on the rollers...and give you a waiver...its happened to me and my friends with low cars
Old Jun 17, 2006 | 08:34 AM
FDNewbie's Avatar
Sponsor
Austin, this ain't Hickville, MD They'll flag you for the low suspension and fail you for state inspection too lol
Old Jun 17, 2006 | 09:17 AM
RE-Amemiya's Avatar
Not the company
Try Ferrari of Washington...i don't know about emissions and such...but i know they are mod-friendly with a few 350Z's that i know of. I"m going to try to take my car there when i need the work done.
Old Jun 18, 2006 | 02:40 PM
kotic-zx's Avatar
i think u wrong i used to inspect cars in va and if ur car can not get on the rolls u get a rejection from testing!! no waiver is issued
Old Jun 18, 2006 | 03:12 PM
FDNewbie's Avatar
Sponsor
He's right in the sense that that trick works in MD. VA is a TOTALLY diff ballgame...
Old Jun 18, 2006 | 03:20 PM
kotic-zx's Avatar
take the word from an ex inspector
Old Jun 18, 2006 | 03:22 PM
FDNewbie's Avatar
Sponsor
Read closer. I said it's true in MARYLAND. It doesn't matter what your experience is in VA. Maryland is a different STATE. And I know for a FACT that what Austin says is true. It may not be correct, but it's commonplace. Again, your experience as an inspector in VA is inconsequential here...
Old Jun 18, 2006 | 03:28 PM
kotic-zx's Avatar
as a mater of fact my license just got reinstated for emissions but not for safety but i guess my experience as an inspector in VA is inconsequential here...
Old Jun 18, 2006 | 03:34 PM
FDNewbie's Avatar
Sponsor
For the nth time, it IS inconsequential. Different states have COMPLETELY different rules and regulations. If you'd like to do a SEARCH and find out just how many ppl on this forum who live in MD use that trick in MD, successfully, time and time again, you'd save yourself from looking like you don't know what you're talking about
Last time I'm gonna clarify this for you. VA is NOT MD. They're two separate states. Your experience in VA in NO WAY carries over to MD. You're comparing apples and oranges. Let it go.
