What clutch pedals can I use?
Old Jun 4, 2006 | 08:25 PM
PERTANO's Avatar
THE TOYOTA GUY
I am going to convert my RX-4 to a 5 speed but I need to know what clutch pedal assembly I can use for the conversion. Or if anyone has a set of RX-4 pedals please let me know. I recently picked up a bridgeported 13b and I don't think the automatic will work with the engine. I found a Turbo II tranny for the swap so I just need the pedals.
Old Jun 4, 2006 | 09:38 PM
trainwreck517's Avatar
Rx-hippie
Not sure about the rx-4, but on my rx-2 which was auto the orginal assemply would work, just needed a longer shaft bolt for the pedals and a clutch pedal, I got the shaft bolt from hardware store, pedal from a 1st gen, and master clutch cylinder from a 1st gen. I'm sure you might be able to do something simlar on the rx-4.
Old Jun 6, 2006 | 07:46 AM
SBMotors's Avatar
Feel the Experience
I used a 1st gen pedal assembly on mine. The only things I had to modify was on the clutch master cylinder and the stop-light switch location. On the clutch master cylinder I had to remove the mounted bolts and put in longer ones to get through the firewall. On the stop-light switch I had to be relocated to the other side of the pedal. I welded a small plate and drill a new hole to mount it correctly. You’ll see once the assembly is in.
Also, I forgot... On the assembly, you'll have to get a longer bolt to get through the assembly. I got mine at Home Depot.
Old Jun 6, 2006 | 10:17 AM
choopacabra530's Avatar
If a repu one would be the same, I probably have one lying around.
Old Jun 7, 2006 | 02:56 PM
PERTANO's Avatar
THE TOYOTA GUY
SB- i found a set from a 83, but it looked way different. What year did you use the pedals from?
Old Jun 7, 2006 | 04:48 PM
SBMotors's Avatar
Feel the Experience
I think I got them from an 81 but I'm not postive. I'd have to see them to see if they look like the ones I have.
Old Jun 8, 2006 | 01:48 PM
rotarydude's Avatar
Back in the saddle again
P
I got a 74 coupe parts car that is about all its got left on it if you want i can pull them out this week end say 50$ + shipping
Dave
