Blinking oil light
Old Jun 3, 2006 | 06:40 PM
series6bat's Avatar
Confused
Blinking oil light
Hey
The problem im having is that when im driving the oil light blinks on and off. Is not low on oil and i thought it may need an oil change or may be the contact on the sensor. I cleaned the sensor and did the oil change with new filter and oil. Have been told it may be due to low oil pressure. Anyone had this fault before and if so how did you go through the process of fixing it. If it is getting low pressure i dont want to drive it.
Any help would be great
Old Jun 3, 2006 | 10:02 PM
chinaman's Avatar
The oil level sensor (side of oil pan) may be going bad. Incorrect oil level?
Old Jun 3, 2006 | 10:19 PM
series6bat's Avatar
Confused
Yea its quite weird. Not sure cause its intermettient.
Just started it up it was doing it to start with, but then stopped and was fine.
Microtech
30
Apr 23, 2016 06:37 PM
