Haltech Where to buy a generic connector
Old Jun 3, 2006 | 01:29 AM
gonzz's Avatar
I need a connector for my 02 sensor. It's a 4 wire that i need to solder in. This way i can just disconnect the connector when i need to remove and install the 02 sensor. I need both sides of the connector. Can i just go to autozone and get one? any ideas?
Old Jul 1, 2006 | 11:36 AM
BASTARD's Avatar
go to the junk yard and find the latest vehicle you can ... cut the connector from the car... take it to your local dealer parts and ask for both male and female connector pins ( you may have to pull the pins out first as most parts guys are morons)... but if you want to be able to plug and play, you should locate a late model vehicle with a 4 pin O2 sensor and use that connector.....
Old Jul 1, 2006 | 11:40 AM
gonzz's Avatar
thanks
Old Jul 2, 2006 | 10:11 AM
Aaron Cake's Avatar
Engine, Not Motor
Many of these connectors are made by Molex or Delphi.
Old Jul 2, 2006 | 12:02 PM
slo's Avatar
slo
registered user
Your local autoparts store should have generic connectors, such as as a trailor connector. Those are usually 4 pin.
jdayau
Nov 29, 2019 12:11 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
