.84 or 1.00 Turbine housing
Old Jun 1, 2006 | 07:59 PM
Jack's Avatar
Do you feel a T04E 57trim P wheel is best balanced with a .84 or 1.00 exhaust housing. The motor has stock ports and looking to run @ 13-14 psi max. Also I do about 15 track events/time trials per year so flow up top is important as well as torque coming out of a corner. Thank You... Howard Coleman and RacerXtreme7 for your pm feedback.....
Old Jun 1, 2006 | 09:09 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i have a stockport cosmo and a t04s with a 1.0 hotside, i feel its a little larege, and just picked up a .84 to try out instead
Old Jun 1, 2006 | 10:57 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
either one will work with a turbo that small.
Old Jun 2, 2006 | 01:38 AM
Turblown's Avatar
Turn up the boost
Its not hard to switch a turbine housing, If you don't like it switch it...
Turblown
Vendor Classifieds
51
Nov 23, 2018 10:52 AM
