Wastegate Actuator
Old May 24, 2006 | 06:53 PM
respo7's Avatar
Wastegate Actuator
Does anyone know how to check the wastegate actuator and what should I be looking for? My car is building boost real fast an the actuator may need adjusting.
Old May 24, 2006 | 07:02 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
stock wg actuator is not adjustable. make sure there is a vac/boost source attached to it and it's not sticking closed.
Old May 24, 2006 | 08:04 PM
respo7's Avatar
The actuator is toward the front right. If so where does the other end of the vacuum off the actuator plug in?
Old May 25, 2006 | 08:55 AM
buttsjim's Avatar
The signal tube for the wastegate actuator takes its pressure directly from the turbo. The attached picture shows this, and describes how to test it.
For what it's worth (and I've posted this before), I use a basketball to test operation of the actuator. Put the big end of an inflation needle in the turbo side of the signal tube, leaving the other end attached to the actuator. Poke the inflation needle into your basketball, and see that the actuator moves.
If the b-ball bounces/dribbles properly, it's at 8 to 10 psi, which is just about right for testing the actuator. This isn't a super-accurate method, but it's effective if you're just trying to make sure everything works.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
