Help! Lost a sale cuz of nagging problem!
Old May 24, 2006 | 12:02 AM
Rocky071's Avatar
Wish I Was This Cool O.O
So after I thought the ol' FC was outta my hair, the guy phones me and tells me he wants to revoke the sale. It won't start. Old habit of this car.
You turn the key, but nothing happens. No turning over of the engine or anything. It's not flooded, it just plain won't start. The car's got an old alarm set up, when you kick the box underneath the steering column and jiggle the wires usually you can get it to actually fire up, in which case the engine gets going no problem.
Is it likely the alarm wiring (I know nothing bout the old alarm setup) or maybe it's another problem? Alternator, starter, battery posts, something completely different?
1988, with the N/A 13B. Help would be appreciated, so that the next sale is actually final!
Oh, and the car is in Calgary if anyone wants to buy it :p
Old May 24, 2006 | 12:12 AM
Josh13B's Avatar
87 Series IV RX7
The transmission. I have an auto and if the selector isn't in the spot correctly it just does nothing. I alternate between P and N to see if it will start. If the needle jumps when you try to start it, then it just needs a bit of throttle to get going.
I took my car to the auto electrician and he cleaned the battery terminals and run a dyagnosic on the starter and battery. It is just tempermental.
Old May 24, 2006 | 12:17 AM
driftin8ez's Avatar
did the alarm have a remote start feature? Maybe this did something with the clutch switch. Cheack and make sure that it is still intact and that it is pushed in all the way where you go start the car. Also if there is a bad ground for the starter the starter will make a click noise but it wont turn over.
Old May 24, 2006 | 01:22 AM
Boostmaniac's Avatar
Same problem here. It randomly acts like I have a dead starter then for no reason like 30 minutes later, the starter will engage like there was never a problem.
My guess.... wiring.
Old May 24, 2006 | 02:21 AM
1SWEET7's Avatar
Now With 10th AE Fun!
I was having a similar problem once in a while. It turned out my battery was nearing it's end, and my terminals were corroded all to hell. Got new terminals and a new battery and haven't had a problem with that ever since.
Old May 24, 2006 | 02:24 AM
Apathy's Avatar
dAracIngPhaRmaCist
It could be the ignition lock cylinder. It might not be contacting properly that's why it works after you kick it and move **** around. L8ter.
Old May 24, 2006 | 02:51 AM
Weird, I'll check it out, but my terminals don't look to bad.
Old May 24, 2006 | 02:57 AM
idsigloo's Avatar
Needs more Displacement.
If it is an alarm problem there is fuse in the box you can remove and that will disable the alarm, then that problem won't exist anymore. If you remove that fuse and it keeps doing it, then we just confirmed it's not the alarm. I'll look for a picture of the fuse box.
Old May 24, 2006 | 07:52 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
i had a similar problem too, ended up being a combination of lose starter solenoid wiring and a bad clutch engage switch
Old May 24, 2006 | 08:00 AM
My5ABaby's Avatar
Rotaries confuse me
7.5A Meter Fuse connects to the Alarm System. Smack dab in the middle of the fusebox. If you take it out a lot of stuff won't work, but your car should still start. Just a FYI so you don't freak out.
Old May 24, 2006 | 08:03 AM
RRTEC's Avatar
Rotartist
That is why I am always OVERLY honest about issues so they aren't surprised when something like this happens..
Old May 24, 2006 | 08:48 AM
bl0d's Avatar
I had a similar problem on my old Camry. At first i thought it was a bad battery (tested on the low side of things, so replaced it), but it actually ended up being a loose connection on the wires to the starter.
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
