Clutch Release Cylinder volume?
Old May 22, 2006 | 07:29 PM
Jodoolin's Avatar
My son had very limited time but we did flush the brake fluid. Usually do so every two years. Started to flush clutch fluid but did not complete. 4 - 5 pumps and he really had to leave. Long story short, flushed before on another S5 and it took only a few pumps to clear. This was longer maybe because I tended to close the valve sooner than I could have gotten away with. Anywho, the FSM does not list the fluid volume in the clutch system. Any one got a good estimate?
As an aside, for more than $50.00 I bought Acrton brake bleed kit. One of those with a vacuum pump. Even using the silicone sealer it was near impossible to get a good seal and draw out the brake fluid. I gave up and put the pos in a bin never to use again. Has anyone had better luck?
Evan Kurtz
Sep 13, 2015 08:40 PM
