Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Haltech options
Old Feb 15, 2002 | 04:37 PM
Haltech options
Am i right in saying the E6K can be used to control the Electric rad fan?
Do the E6K's work ok with Partail Bridge?
What Ignition system would you recomend to complement the E6K?
Old Feb 16, 2002 | 03:09 AM
HWO's Avatar
HWO
inteligent extratarestril
to control the radiator fan you just wire whichever PWM output you have asigned to the thrermofan to a relay and then run the fan to the relay, you can set the turning on and off temps of the fan
Yes works fine on a partical bridge
ignition system - stock CAS, Stock Coils, Stock ignitors, B10EGV plugs, good leads and BOBS YA UNCLE
unless you are planning on running methanol and or over 20psi then the stock coils/ignitors are more than up to the task
Old Feb 21, 2002 | 12:22 PM
Cheers.
renjiv2
57
Jan 25, 2024 03:34 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
manoflego
19
Sep 30, 2015 05:19 AM
