Sponsored by: CARiD
need help
Old May 10, 2006 | 06:01 AM
tish's Avatar
Newbie
need help
hi im new to the forum and would like sum help iv got a 1989 Mazda RX7 FC3S and the other day and 2 of the belts had snaped the altornator and the other one that goes to the left of the engine as they snapped off the engine over heated put new belts on it and now it wont start at all it turns over and thats about it iv taken the cover off in the boot were the fule pump is and pulled the two pipes off and no petrol is goin thru the pipes could sum1 help plz
Old May 10, 2006 | 11:43 AM
SureShot's Avatar
Seduced by the DARK SIDE
Welcome to the forum.
If the engine is not cranking or running, the fuel pump is cut off as a safety feature.
There is a 2-pin test connector comming from the wiring harness near the thermostat housing.
If you jumper those pins the pump will run whenever the key is on.
I have a copy of the on-line factory service manuals at the link in my sig.
The above is from the "fuel & emmissions" section.
Download & print whatever you need.
Also, check the FAQ threads pinned at the top of the forum.
You may be flooded.
Old May 10, 2006 | 07:20 PM
tish's Avatar
Newbie
hi mate iv had a lot at the car to find out im not get a spark at the plugs or both the coils would u know what it could be as i thought it was weird how both coils dont work
Old May 11, 2006 | 06:40 AM
SureShot's Avatar
My first guess would be the CAS. Maybe a bad connector or broken wire.
Here's a good link showing how to blink the codes.
http://www.1300cc.com/howto/how2/codes.html
