Sponsored by: CARiD
What should I set my fuel pressure at??
Old Apr 27, 2006 | 02:30 AM
2Lucky2tha7's Avatar
Back at it again!!
Exclamation What should I set my fuel pressure at??
I know this has been reiterated probably several times, but I need to know the base pressure (0psi/vacuum) for the fuel pump. I have a Walbro fuel pump, fuel pressure regulator, and 550/180cc injectors. This is for a Cosmo 13B-RE with high compression rotors. What should I set the fuel pressure at??
Brian
Old Apr 27, 2006 | 03:43 AM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
Did you make a RE, NA, i dont get it.
Old Apr 27, 2006 | 08:27 AM
Back at it again!!
No, it's not an N/A. Just high compression rotors on a turbo setup
Rotospectre
Mar 28, 2018 03:33 PM
