tested 545whp on stock fuel lines. walbro pumps, twin stock fuel regs
Old Apr 22, 2006 | 12:00 AM
bobybeach's Avatar
Hi guys, a litle of the topic but still very relavent to most of you guys running large single needing adaquite fuel supply.
basicaly ive tested 545whp with stock fuel lines in an fc and twin stock fuel regs using only 2 walbro intank pumps.
pls check the link ive already posted in the 'second generation forum' it has all the testing info and conclusions all explained.
cheers!
https://www.rx7club.com/showthread.p...2&page=1&pp=15
Old Apr 24, 2006 | 01:51 PM
7-sins's Avatar
thats not paint....
Good to know, did you T the two pumps in the tank or did you use the stock send and charcoal filter hard lines up to the motor?
Old Apr 25, 2006 | 08:16 AM
bobybeach's Avatar
I was going to use the charcoal filter line but there only about 3mm diameter unlike the huge ones found on the fd3s, So instead ive just had them T together in the tank.
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
