Starting from near scratch block - need list of parts required, just for reference =)
Old Apr 13, 2006 | 09:29 PM
dhahlen's Avatar
FD Under Construction =P
I would like a list of parts that I am going to need to put together this engine. I'll let you know what I have, and then... if you could just add what I'll need that would be great. I am going to try and gather all the parts at once so I can just start piecing things together, but I know I am going to be missing a few things so thats why I am starting this thread. Main focus in the engine itself...
Currently Have:
Engine Block mounted in Engine (BARE) aside from:
Upper Intake Manifold
Lower Intake Manifold
Intercooler (Front Mount)
Radiator
Power Steering
Single Turbo
Turbo Manifold
WasteGate
Oil Lines for turbo
Fuel Inejctors (1000/1600cc)
Here is the list that I started for parts needed:
-Oil Metering Pump
-Oil Metering Lines, Steel
-Alternator
-Water Pump
-Blockoff Plate Kit
-Power Steering Pulley
-Coils (Leading and Trailing)
-Throttle Body
-Intake Elbow (Greddy)
-Crank Angle Sensors
-Crank Angle Pulley and Crank Wheel
-Coolant Filler Neck w/Sensor
-Gaskets for all above components
-Knock Sensor
-Oil Pressure Sender
-Oil Filter Pedestal
-Oil Filler Neck
-ECU Harness
-Assorted Vac Line 8, 10, 12mm
-Blowoff Valve
-Coil Harness
-Spark PLugs
-Plug Wires
-Upper Radiator Hose
-Lower Radiator Hose
-Check Valves (dunno which sizes, or tolerances)
-Air Seperator Tank
-Aftermarket Fuel Rails
-Fuel Line
-Fuel Pressure Regulator
Keep adding to the list, I would appreciate it!
Thanks,
-Darren-
Old Apr 13, 2006 | 10:48 PM
c00lduke's Avatar
I dont seem to see the water temp sensor on your list. The one that is under the oil pres. sender.
Old Apr 13, 2006 | 10:58 PM
technomentor's Avatar
Brings Order to Chaos
Just go pull up an FD FSM and look in the engine section. You will get an exploded view of everything you need including part numbers. Using that, I'd put my list in Excel so you can sort and total the price for everything.
I've converted several of the cars systems to Excel spreadsheets to faciliate figuring out out much it will cost me to restore them. I'm sure many other people have done the same but I have seen very few posts. I did post a list last year, but got very little response.
Old Apr 14, 2006 | 06:26 AM
dhahlen's Avatar
Got a water temp sensor sitting right in front of me... forgot that one =)
Old Apr 14, 2006 | 02:47 PM
2a+RoN's Avatar
i thought your car was together and running??
Old Apr 14, 2006 | 04:19 PM
dhahlen's Avatar
Oh - this isn't for my car.. lol.
cristoDathird
28
May 30, 2019 08:47 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
