Its all about the numbers...
Old Apr 11, 2006 | 02:29 PM
RX7JCHIII's Avatar
With this setup what kind of rwhp can I run? Thanks
Power FC/Commander and Apexi Boost Controller
Shane Racing Stage 2 turbo kit
HKS BOV
HKS Wastegate
M2 Med Intercooler
Resonated Mid Pipe
RB Single Exhaust
850 primary injectors
1300 secondary injectors
Indigo Pulley Kit
Indigo Aluminum Flywheel
Upgraded Radiator
Act HD Clutch Set
Koni Adjustables and Eibach Springs
Brembo Rotors (Drilled and Slotted) – Braided Lines
Apexi Turbo Timer
Old Apr 11, 2006 | 04:13 PM
Sled Driver's Avatar
The Anti-Prius
Apexi Turbo Timer puts you over 400hp @ 10 psi
Otherwise only around 320-340hp @ 15 psi
Old Apr 11, 2006 | 04:19 PM
Brent 94's Avatar
Not to mention those drilled and slotted brake rotors will put you near 400 because of the holes and slots!
Seriously though i'd guess your around 320rwhp, but if you have all that stuff you say you have, obviously you have tuned the car, so why don't you ask the shop that dyno tuned the car what you made at the wheels.
Old Apr 11, 2006 | 04:22 PM
RX7JCHIII's Avatar
really I might go ahead and get another one and run them sequential....
Old Apr 11, 2006 | 04:41 PM
RX7JCHIII's Avatar
planning on dyno here shortly....put it in the shop and had a lil body work and paint job on it and did a few upgrades while it was down.
Old Apr 11, 2006 | 04:43 PM
RX7JCHIII's Avatar
next time i will be sure not to copy and paste my mod list geesh tough group
Old Apr 11, 2006 | 05:20 PM
Brent 94's Avatar
it's all fun and games, don't worry bout it. So sense you have never dyno tuned the car, im assuming you programmed the larger injector size into the computer yourself? if not, than your car is dumping huge amounts of fuel into the motor due to the larger sizes.
RacerJason
Canadian Forum
Oct 12, 2012 08:02 AM
RacerJason
Race Car Tech
Sep 25, 2012 03:56 PM
Nateness
Apr 12, 2005 10:16 PM
