Will these wheels fit?
Old Apr 7, 2006 | 01:41 PM
88rx7gxl's Avatar
Would these wheels fit my car (correct offset)? $300 shipped is kinda cheap isnt it? Do you think they would look goofy? My car pic is below. 90 TII.
http://cgi.ebay.com/ebaymotors/17-WH...QQcmdZViewItem
or
Which would look better?
Old Apr 7, 2006 | 01:51 PM
CyborgRyu's Avatar
Drift FC
whats the width?
n/m 17x7
+40 offset
5x114.3
yes, this will fit.
if not, a thin spacer will clear it. like 2-3mm
Old Apr 7, 2006 | 01:56 PM
classicauto's Avatar
Crash Auto?Fix Auto.
id double check with the seller if the pic is of actual product...because he's got 4 bolt rims on there....
Old Apr 7, 2006 | 02:05 PM
88rx7gxl's Avatar
I think the pic is just representing the wheel style. Not the actual lug pattern. I will check to make sure. Anyhow, does everyone agree that a 17x7 +40mm offset will fit? Also, what tires would be the same as stock? I came up with either a 205/50-17, or a 225/45-17. Sound right? Thanks
(stock is 205/55-16)
Old Apr 7, 2006 | 03:46 PM
rotary downshift's Avatar
you can get away with a 215/40/17 ..... i have that same wheel style with a 42 ofset and a the tire size i listed with no spacers and i have no clearance issues
Old Apr 7, 2006 | 04:02 PM
88rx7gxl's Avatar
The tires you mentioned are an inch shorter than my factory tires. Do you have any pictures of these on your car? Is your car lowered some? Thanks
Old Apr 7, 2006 | 04:41 PM
Black91n/a's Avatar
I'd recommend going with a wider wheel. In using 7 inch wide wheels you're limiting yourself to 225's. That is the most you can fit in front practically anyway, but with a TII you may want to get wider rear tires. You can get stock mustang wheels that are 17x8 with a about a 30-32mm offset that fit perfectly and fit a 225/45/17 nicely with no rubbing, and the wheels can accomodate 245/40/17's. The stock mustang wheels are cheap, plentiful and strong, and the GT ones aren't too heavy.
Those wheels will fit fine, you can run 225/45/17's on them, but you may need a small spacer up front to keep them from rubbing on the suspension.
fidelity101
13
Aug 31, 2015 07:47 PM
