Purge Valve and other questions
Old Apr 6, 2006 | 06:48 PM
t-too's Avatar
Fast when it works
Hey guys what did you do with your purge valve after you removed emissions? I cant remember exactly where the lines went, but i'm assuming theres a way to simplify it, right?
Do you need to tee it off of the vent for the oil neck, the way it is run originally?
I know this is alot of questions but one more- what is the disadvantage of removing the charcoal canister?
Old Apr 7, 2006 | 11:10 AM
t-too's Avatar
Fast when it works
Not cool, not cool at all... I've seen small oil catch filters put on the outlet, so that works okay right?
Old Apr 7, 2006 | 11:25 AM
Aaron Cake's Avatar
Engine, Not Motor
I've covered this many times in the past. A search for "purge valve" and my name will likely turn up all the info you need.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
