Auto trans idles in park/neutral but dies in gear
Old Apr 6, 2006 | 06:47 PM
jennypenny's Avatar
Newbie
I have a '91 auto convertible that runs fine in neutral or park but barely runs and has no power when I put in in gear. The check engine light comes on as well but no code is determined when put on a diagnostic machine or scanner, not even at the Mazda dealer. If I shut the car off and restart it in park or neutral it again runs fine but repeats the problem when put in gear. Is the transmission controlled by solenoids or vaccum? I have done no mods and bought it from the original owner, a woman in ger 50s or 60s. I have, however, had the computer replaced at considerable expense but to no avail.
I have tried disconnecting the battery for quite a while and reconnecting it but no change other than the check engine light going off. Any ideas??
Old Apr 6, 2006 | 07:21 PM
alexdimen's Avatar
TANSTAFL
fluid level; check it as per the FSM/haynes manual
if that doesn't work, swap in a manual and 4.1 rear end
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
R7rexy
19
Sep 2, 2015 10:24 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
86glxNA
Aug 22, 2015 08:54 PM
