(BRAKES) Tip for bleeding brakes
Old Sep 2, 2004 | 11:05 PM
Rx-7Doctor's Avatar
For all you 7ers that have tried bleeding your brakes by yourself. Invest in a set
of speedy bleeders available at most parts stores. They are one way bleeders
that take the place of your regular ones. You just pump up like normal until you
have a steady stream of fluid then close the valve and go onto the next one.
Every 30k you should be completley changing your fluid. Remember to start at the
furthest point, RR, then LR, then RFT, then LFRT. Then your done. rx7doctor
Old Sep 2, 2004 | 11:12 PM
bouis's Avatar
I didn't find the $3 speed bleeders to be very effective.
Old Sep 2, 2004 | 11:22 PM
Rx-7Doctor's Avatar
These are replacment bleeder valves that replace your stock ones in your calipers. They sell
for $15.00 a pair at napa. rx7doctor I think you thought i was referring to that piece of hose
with a siphon on it, sorry about that. rx7doctor
Old Sep 2, 2004 | 11:37 PM
bouis's Avatar
Ah, I never tried those. Thanks for the tip. I may invest in a set when I do a brake job in the next few months.
Old Sep 3, 2004 | 12:13 AM
DJAngelicon's Avatar
a.k.a TheLatinHeat
Thanks for the tip rx7doctor hopefully will do this soon and I will use what you said. But were is napa ? and what is that tool you are talking about?
Old Sep 3, 2004 | 01:07 AM
Rx-7Doctor's Avatar
call 1-800-let-napa for the nearest store, also if you have AAA towing card you can get discounts on your parts to. BRitish victoria also sells these as so does many auto parts stores. Not talking about tool latin heat, but bleeder valves that install in your calipers and
wheel cylinders if you have drum brake on the rear. rx7doctor
Old Sep 3, 2004 | 03:58 AM
slashdawg00110's Avatar
RTFFAQ
Thanks for the idea. I'll have to check them out.
Old Sep 3, 2004 | 01:40 PM
Blake's Avatar
I really like Speed Bleeders, having used them on most of my vehicles for the last four or so years. Most of us don't have a helper to pump the brake pedal while we crack the stock bleeder valves...and, some of us know the stress caused to a long term relationship by asking our wives/girlfriends to help (particularly when they DON'T LISTEN! Argh!). Anyway, Speed Bleeders are a great "tool" for preventative maintenance.
Another fine product for one-man brake bleeding is a pressure bleeder. Pro-quality ones cost over $300, but Motive makes one for under $50. You can also build your own from a small garden sprayer for a bit less. These are awesome because (1) there is a reservoir of brake fluid in the container that automatically tops off the master cylinder reservoir as you bleed, so you don't have to constanty stop to top off, and (2) because it's pressurized, you don't have to pump the brakes at all! This makes brake bleeding very, very quick and trouble free. The only down sides are having to lug around a device for brake bleeding and you waste a bit more brake fluid because the leftover fluid in the container should be discarded (brake fluid absorbs moisture from the atmosphere). If you do most of your brake bleeding at home, the pressure bleeder is a great investment. Same, too, if you don't mind hauling equipement to the track. But, the nice thing about Speed Bleeders is they are always there when you need them.
One thing I don't recommend are those cheap "one man brake bleeding" devices sold at most autoparts stores that use vacuum. I hate vacuum brake bleeders, particulary the cheap POS hand pump ones. Not only are they inefficient, but they tend to draw air around the threads of the bleeder valve, compounding the problem you are attempting to solve.
BTW, the main reason to bleed brakes is not because air infiltrates the system (it doesn't, unless you disconnect something for maintenance); it's because atmospheric moisture is absorbed into the brake fluid in the MC and works it's way to the lowest part of the system: the brake calipers. This water-saturated brake fluid has a rediculously low boiling point comparred to fresh/dry fluid, so brakes can fade *very* quickly, leaving you no hope of slowing the car down when you need to most. The vapor caused by boiling is "compressible", so stomping on the brakes is like steping on a sponge, transmitting very little pressure to the caliper pistons. Bleeding the brakes frequently keeps the fluid "dry" and, thus, able to handle the heat generated by braking. Brake fluid usually turns a tobacco brown color when saturated with moisure, so you bleed until the fluid is as clear as it comes from the bottle (a transparent amber color). For a street car, you should bleed brakes at least twice a year. Any track activity should mandate bleeding on a daily basis, prior to running. It's also a great opportunity to inspect the brake pads, caliper, rotors, hubs, etc.
Old Sep 3, 2004 | 06:14 PM
Rx7carl's Avatar
Airflow is my life
Blake, I highly agree about the homemade Motive style bleeder. Ask pratch or Yapakanichi about mine. Heres my take on the whole thing. Usually you are bleeding a system that doesnt have a new MC. Well folks, anyone whos worked on brake systems can attest to the fact that the only clean and shiny portion of a MC that has any use on it is the normal piston travel during usage. The rest of the bore gets rusty and cruddy from accumulated water in the system and dirt/particles of old piston rubber. When you go and do the helper technique, or speedbleeder technique you invariably push the pedal all the way down. So what happens now? You drag the rubber MC rubber piston seals across a nasty dirty part of the bore and it gets nicked up and chopped to hell. Sure, the brakes work great afterwards. But within a few weeks you start to notice that the pedal fades/bypasses at stoplights cause the seals have been damaged. And this deteriation soon causes your MC to crap out.
Moral of the story. Use the motive style bleeder, or only move the pedal in short strokes when you bleed. Trust me, I been thru this scenario with alot of cars for many years before I figured this out.
Old Sep 3, 2004 | 06:46 PM
RotaryRyan's Avatar
DSM
Its sweet, I can get klike 10% off anything at napa, cause my stepdad use to manage this tire store here. Also, we're checking on getting wheels and tires from this wholesale place.
Old Apr 4, 2006 | 11:48 AM
mbaha's Avatar
Bringing it back from the dead!
Is there a particular size of speedy bleeders needed? I have front disks and rear drum brakes.
Old Apr 4, 2006 | 12:09 PM
vipernicus42's Avatar
Rotoholic Moderookie
Go to the website.
Click on the link that says "Automobile Sizes"
Scroll down the list and find your car
Bingo.
I found it in about 30 seconds.
Jon
Edit: though I'm glad you dragged this back from the dead.. Damn good thread and I hadn't seen it before!
RX7 78-91 SB7100 SB7100 - SB7100
The1Sun
Sep 15, 2015 04:45 PM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
