Some last minute questions on Single Install
Old Mar 30, 2006 | 09:46 PM
IEatVipers4Brkfast's Avatar
Just finishing up a GT35R install. Running all the new stainless fuel lines, oil lines and water lines, cutting all the extra connectors on the harness, and installing the resistors and new injector harness.
Quick questions,
can i tape over the resistors? They are in a brass looking case, but i dont know if they will get too hot and melt the tape.
Should i somehow prime the turbo with oil and/or water before firing up the car?
Any tips on installing the motor with the Downpipe and wastegate on already, or should i take them off?
Oh yeah, also got a new low oil sender unit since the wire broke when removing the engine, can i get at it to install the new one after the motor is in?
Thanks for all the help the forum has given me with my many, many searches!!
Shane
Old Mar 30, 2006 | 09:51 PM
Oh, one more i forgot:
I have a spec stage 3 6 puck clutch, and lightened SR flywheel, the clutch has no dowel pins into it and the flywheel. Is this OK? Where would i get the 3 dowel pins to put in thee?
Is it a factory item?
Old Mar 31, 2006 | 10:03 AM
Anyone?!?
Old Apr 1, 2006 | 07:54 AM
dubulup's Avatar
development
Originally Posted by IEatVipers4Brkfast
1-can i tape over the resistors?
2-Should i somehow prime the turbo with oil and/or water before firing up the car?
3-Any tips on installing the motor with the Downpipe and wastegate on already, or should i take them off?
4-Oh yeah, also got a new low oil sender unit since the wire broke when removing the engine, can i get at it to install the new one after the motor is in?
1-yes
2-it will prime fine when you prime the motor
3-have a friend help guide (maybe install the dp after motor is in)
4-yes
Old Apr 1, 2006 | 08:25 AM
JDK's Avatar
JDK
The brass looking case is a heat sink, I think taping them up would be a mistake.....
Old Apr 2, 2006 | 09:13 AM
Thank you
CaptainKRM
14
Aug 26, 2015 09:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
