ok this is what i did>>>>
Old Feb 9, 2002 | 02:29 PM
NVMYRX7's Avatar
Question ok this is what i did>>>>
ok i had the 3800 hesatation problem in my car and here's a list of thigs that i did..........
>>ecu grounded
>>ran two grounds from the battery to the motor
>>bought and installed two BRAND NEW (not junk yard new!!)secondary
took of the 5th and 6th port thingyies (they had a real good spring too them!!)
>>installed new boost sensor off of a car that had only 70,000 miles
>>installed new main cat
>>installed 2 brand new mufflers
Is there anything i am missing???
i know i need to ground the boost sensor but where do i ground it to???
And what is this thing about grounding the EXHAUST???? WTF
i am putting more money in this car than i bought it for!!!!!
HELPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!
Thank You
Josh
Old Feb 9, 2002 | 02:35 PM
TonyTurboII's Avatar
Glock Lover
Ok, next you want to run a wire from the bolt that holds your antenna in place to your battery. I think that might cure your problems...
Old Feb 9, 2002 | 08:06 PM
7Rebel's Avatar
Re: ok this is what i did>>>>
>>ecu grounded
Thank You
Josh
Maybe replace the TPS
Old Feb 9, 2002 | 09:11 PM
Icemark's Avatar
Ground the motor to the body, not just the battery.
Same thing for the battery.
O2 sensor
plugs and plug wires
