Haltech Idle speed motor connector need on E8
Old Mar 28, 2006 | 10:36 PM
GOTBANNED?'s Avatar
Boost Addict
Exclamation Idle speed motor connector need on E8
Do i need to use the idle speed motor connector that comes off of the ECU connector on the E8? Is it needed?
Also my car is a FD3S
Old Mar 29, 2006 | 01:44 PM
crispeed's Avatar
'Tuna'
No.
The FD3S stock idle control use a BAC valve so you would need to use one of the PWM outputs from the E-8. The BAC use two wires one from the PWM output and the other from a switched 12v ignition.
The idle speed connector on the E-8 is used to control stepper type idle motors or 4-wire types. On the FD3S you can use the idle speed connector to control the oil metering pump if you wish too.
Old Mar 29, 2006 | 09:19 PM
GOTBANNED?'s Avatar
Boost Addict
thanks alot.
incubuseva
14
Sep 3, 2015 12:37 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
86glxNA
Aug 22, 2015 08:54 PM
befarrer
Aug 14, 2015 04:18 PM
